| ORCA - 1/6-Scale Boat Project | |
+14Wolf_Soldier64 Rossini Beatlefan Dreadnought SlackElastic Jet- FIELD STATION 42 Gunner Munro Reddragon Rogue-Trooper somekindajoe Rustygun Professor Gangrene Fan inntruderr61 18 posters |
Wolf_Soldier64 Moderator
Posts : 2476 Join date : 2012-11-12 Age : 59 Location : Reading, Berkshire
| Subject: Re: ORCA - 1/6-Scale Boat Project Sat Apr 13, 2019 8:52 pm | |
| Well Quint looks good in place now......... to build Cheif Brody, and Hooper.... _________________ Its better to Burn out than fade away
Rogue-Trooper Green Beret
Posts : 2436 Join date : 2016-09-11 Location : Bedfordshire
| Subject: Re: ORCA - 1/6-Scale Boat Project Sat Apr 13, 2019 8:53 pm | |
| Outstanding build _________________ NEW AND IMPROVED EXTENDED WORKSHOP COMING SOON
Reddragon SCRAMBLE PILOT
Posts : 510 Join date : 2012-11-11 Age : 65 Location : South Wales
| Subject: Re: ORCA - 1/6-Scale Boat Project Sun Apr 14, 2019 12:18 am | |
| _________________ “Life can only be understood backwards; but it must be lived forwards.” | |
| Subject: Re: ORCA - 1/6-Scale Boat Project Mon Apr 15, 2019 2:17 am | |
Gunner Munro Arctic Explorer
Posts : 1103 Join date : 2016-06-23 Age : 63 Location : Northwich Cheshire
| Subject: Re: ORCA - 1/6-Scale Boat Project Thu Apr 25, 2019 6:40 pm | |
| Many thanks Steve, appreciate your kind comments _________________ Its better to Burn out than fade away
| Subject: Re: ORCA - 1/6-Scale Boat Project Thu Apr 25, 2019 6:41 pm | |
| Hopefully guys I will soon be able to do some more work on the ORCA, got some outfits for Chief Brody and Hopper _________________ Its better to Burn out than fade away
FIELD STATION 42 Admin
| Subject: Re: ORCA - 1/6-Scale Boat Project Thu Apr 25, 2019 8:00 pm | |
| Yikes! This is amazing!I hope you don't mind a barrage of questions! Did you build this from a plan you found, or are you making it up as you go? If it is your own plan, how did you determine the dimensions? Is most of the construction done with wood? How did you get the sides of the bow to curve like that? What are you using to secure the pieces together: screws, tiny nails, glue? What is the total length and width? It looks like about 3-1/2 to 4 feet (100 - 125 cm) long. Fantastic work! And your Cap'n Quint looks as "screen accurate" as the boat! _________________ ... DAVE
Jet- Medic
Posts : 680 Join date : 2012-11-17 Age : 53 Location : Yateley
| Subject: Re: ORCA - 1/6-Scale Boat Project Sun Apr 28, 2019 1:23 pm | |
| Fantastic Mark , great effort especially as you aren't at full fitness at the moment | |
SlackElastic Medic
Posts : 693 Join date : 2012-12-03 Location : Cosham, Hants, UK
| Subject: Re: ORCA - 1/6-Scale Boat Project Sun Apr 28, 2019 6:07 pm | |
| it's epic I love it! | |
| Subject: Re: ORCA - 1/6-Scale Boat Project Fri May 17, 2019 10:06 pm | |
| - SCU_HQ wrote:
- Yikes! This is amazing!
Fantastic work! And your Cap'n Quint looks as "screen accurate" as the boat! Dave, Many thanks for your comments on my build of the Orca, I've only just seen your message about the build of it, I'll explain what I did, first of I got a image of the boat, then laid a action man down on a piece of large paper and drew the size of the top section of the bridge side on, to get the height, then got a a image of the front were the shark jaws are mounted and drew the size of that against the action figure, so that was cut and sawn to size, then for the cabin part, got the size with the figure and cut that from MDF 8mm then it was get the length of the boat, With the bridge and the cabin bits done it was getting the length of the boat which worked out tobe 51 inches long, with out the plank part where Quint stands at the front of the boat which is in the making now Very Happy Hopefully I will able to get some more work done soon I'm in the process of bashing Brody and Hooper, Hope this answers your question Regards Mark, _________________ Its better to Burn out than fade away
| Subject: Re: ORCA - 1/6-Scale Boat Project Sat May 18, 2019 2:36 am | |
| Thank you for the detailed information about your process. Your technique for determining the size led you to a very convincing scale result! _________________ ... DAVE
| Subject: Re: ORCA - 1/6-Scale Boat Project Sat May 18, 2019 2:55 am | |
| That boat is shaping up beautifully! Great work! Building props in 1/6 means that things tend to get very large indeed!
I too have a great white shark that would be about the scale you need. See it in my MAM Kitbash post called "On the Menu?". |
Dreadnought Moderator
Posts : 510 Join date : 2017-07-10 Age : 54
| Subject: Re: ORCA - 1/6-Scale Boat Project Fri May 24, 2019 8:46 pm | |
| What a fantastic build! Looks like you had a lot of fun doing that. _________________ Real heroes don't die... they just reload.
| Subject: Re: ORCA - 1/6-Scale Boat Project Fri Nov 15, 2019 10:07 am | |
| I finally got to do Hopper and Brody..... _________________ Its better to Burn out than fade away
| Subject: Re: ORCA - 1/6-Scale Boat Project Fri Nov 15, 2019 10:09 am | |
| The Orca is still on going building the Mast but a slow process _________________ Its better to Burn out than fade away
| Subject: Re: ORCA - 1/6-Scale Boat Project Fri Nov 15, 2019 10:12 am | |
Posts : 14863 Join date : 2012-11-07 Age : 51 Location : Birmingham, England
| Subject: Re: ORCA - 1/6-Scale Boat Project Fri Nov 15, 2019 11:01 am | |
gibri Admin
| Subject: Re: ORCA - 1/6-Scale Boat Project Fri Nov 15, 2019 11:38 am | |
| Looks better every time I see her!!! Looking forward to seeing it with the mast. The figures look great too. IIRC from the film, that boat was in a dirty and disheveled state. Yours looks so nice and clean I was wondering if you plan to take the plunge and do some weathering to her? Love this build!!! | |
| Subject: Re: ORCA - 1/6-Scale Boat Project Fri Nov 15, 2019 12:35 pm | |
| Many thanks Brian and Dal, Bri.. I do plan to weather the Orca and I plan to get down to the sea and take some sea photos once I get the Mast and the rigging up with some other details _________________ Its better to Burn out than fade away
| Subject: Re: ORCA - 1/6-Scale Boat Project Fri Nov 15, 2019 9:39 pm | |
| TRULY EPIC BUILD AND SPLENDID FIGURES!!!! |
| Subject: Re: ORCA - 1/6-Scale Boat Project Sat Nov 16, 2019 1:50 am | |
| Wow awesome! _________________ JIM...
| Subject: Re: ORCA - 1/6-Scale Boat Project Wed Jan 22, 2020 8:32 am | |
| Been making a Chair for the Orca for Quint _________________ Its better to Burn out than fade away
Last edited by Wolf_Soldier64 on Wed Jan 22, 2020 8:42 am; edited 1 time in total | |
| Subject: Re: ORCA - 1/6-Scale Boat Project Wed Jan 22, 2020 8:33 am | |
| Subject: Re: ORCA - 1/6-Scale Boat Project Wed Jan 22, 2020 8:35 am | |
| Quint has a seat see how comfortable it is lol _________________ Its better to Burn out than fade away
| Subject: Re: ORCA - 1/6-Scale Boat Project | |
