 SLR barrel fix help needed
PH5121
Painted Head (Hard Hands)
SLR barrel fix help needed Empty
PostSubject: SLR barrel fix help needed   SLR barrel fix help needed Icon_minitimeTue Jan 28, 2014 11:54 am
I have built up quite an arsenal of barrel-less SLR rifles.
There is a good model shop not too far from where I work that sells brass and aluminium rods, but when confronted with a display full of rods I have no idea what size I require for the barrel and flash suppressor.
Does anyone have any recommendations as to what size (mm or inches)  is needed? I don't think I have a barrell I can use for comparison purposes.
Paul
PostSubject: Re: SLR barrel fix help needed   SLR barrel fix help needed Icon_minitimeTue Jan 28, 2014 5:29 pm
i use cotton bud stems for the barrel and milliput for the suppressor but there are more ways than that i am sure
ak615
Heavy Weapons
ak615
PostSubject: Re: SLR barrel fix help needed   SLR barrel fix help needed Icon_minitimeThu Jan 30, 2014 12:54 pm
Just ran the micrometer round an SLR barrell is 3.5mm/0.14in anti flash 4.5mm/0.18in also take the rifle with and try the different tubes for look.
There is pleasure in recognising old things from a new viewpoint. affraid Richard Feynman
PH5121
PostSubject: Re: SLR barrel fix help needed   SLR barrel fix help needed Icon_minitimeThu Jan 30, 2014 1:06 pm
Brilliant, thanks for that info.
Andyh
New Recruit
Andyh
PostSubject: Re: SLR barrel fix help needed   SLR barrel fix help needed Icon_minitimeThu Jan 30, 2014 4:22 pm
You can use modelling sprue or there is a mouldable plastic you can buy which does the same job .
Artic Explorer
PostSubject: Re: SLR barrel fix help needed   SLR barrel fix help needed Icon_minitimeThu Jan 30, 2014 7:42 pm
I drilled a hole in the end of mine and stuck a cut down black painted pop rivet stem in and wrapped a lenth of trimmed black insulation tape round end for suppressor!! But that's just me.. bodge up Billy!! Lol!!
PH5121
PostSubject: Re: SLR barrel fix help needed   SLR barrel fix help needed Icon_minitimeFri Feb 07, 2014 2:18 pm
I got to the model shop today armed with the broken barrel off an SLR for comparison and found some aluminium tubing of a suitable size. I got a length of 5/32, 1/8 and 3/32 for the suppressor, barrel and to go inside the barrel into the body of the gun for additional support.
I have enough for dozens of repairs as the tube is in 1m lengths!
Artic Explorer
PostSubject: Re: SLR barrel fix help needed   SLR barrel fix help needed Icon_minitimeFri Feb 07, 2014 5:47 pm
Great stuff Paul.. Be sure to post a photo of one when you have had a crack I/we would love to see.. Smile
PostSubject: Re: SLR barrel fix help needed   SLR barrel fix help needed Icon_minitimeFri Feb 07, 2014 7:59 pm
This is very intresting as I have quite a few barel less guns and rifles, but what do you all use to attach the new barrels  scratch cheers
PostSubject: Re: SLR barrel fix help needed   SLR barrel fix help needed Icon_minitimeSat Feb 08, 2014 4:14 pm
i melt a hole into the broken one with a short bit of a paper clip leaving it stuck in there , then use the milliput
PostSubject: Re: SLR barrel fix help needed   SLR barrel fix help needed Icon_minitimeSat Feb 08, 2014 6:05 pm
Thanks for the tip Jim but what is milliput and where do you get it  cheers Ian
PH5121
PostSubject: Re: SLR barrel fix help needed   SLR barrel fix help needed Icon_minitimeSat Feb 08, 2014 10:05 pm
The aluminium tube is great for gun barrel repairs.
I have done an MP5 and Lee Enfield today. I have a stack of SLRs and various other guns to do.
All it took was a small drill bit and super glue in addition to the tubing.
PostSubject: Re: SLR barrel fix help needed   SLR barrel fix help needed Icon_minitimeSat Feb 08, 2014 10:37 pm
Could you post astep by step how to with pictures in the tips section ,i think everone would appreciate it
Like a Star @ heaven  Like a Star @ heaven  Like a Star @ heaven  Like a Star @ heaven  Like a Star @ heaven  Like a Star @ heaven Like a Star @ heavenSLR barrel fix help needed G.I.-Joe-1964-Lineup-Title_zpsaepa6syh Like a Star @ heaven Like a Star @ heaven Like a Star @ heaven Like a Star @ heaven Like a Star @ heaven Like a Star @ heaven Like a Star @ heaven
PostSubject: Re: SLR barrel fix help needed   SLR barrel fix help needed Icon_minitimeSun Feb 09, 2014 3:45 pm
milliput is a 2 part epoxy putty like stuff that you mix like car body filler paste any good model shop should have it , poundland or failing that ebay hope that helps
PostSubject: Re: SLR barrel fix help needed   SLR barrel fix help needed Icon_minitimeSun Feb 09, 2014 8:11 pm
Thanks Jim
I will try to get some there is a small model shop in Thirsk the town I originally come from I will have a look at that and maybe even in boyes  cheers
Ian
ActionManMobileOperations (AMMO) :: Help and Advice :: Repair-
