| Outboard engine | |
ak615 Action Pilot
Posts : 434 Join date : 2012-11-12 Location : Off the shoulder of orion in the dark near the tanhauser gate
| Subject: Outboard engine Mon Nov 26, 2012 10:46 am | |
| Ok you`ve got your vintage outboard and it dont work right,quick test/tip to see if it`s repairable. Take a 9v battery (the square type found in smoke alarms) peel the battery sticker off inside the battery compartment (if its still there) push the battery connections onto the brass connections arrowed this will bypass the swtch you may may need to flick the propeller in either direction.NOTE ONLY APPLY THE 9v BATTERY FOR A FEW SECONDS AT A TIME AS THE INCREASE VOLTAGE COULD DAMAGE THE MOTOR. If it spins then the motor is ok try with a correct battery fitted and normal operation ie swing the clip up If the motor does`nt spin check and clean the contacts for the switch(accessable through the slot underneath. I`ve used this on several non-workers bought off ebay etc and not had one not work yet. | |
Posts : 14781 Join date : 2012-11-07 Age : 51 Location : Birmingham, England
| Subject: Re: Outboard engine Mon Nov 26, 2012 10:48 am | |
| more great tips ak, you are a knowledge of vam mate, well done | |
Cappy Eagle Eyes (Gripping Hands)
Posts : 339 Join date : 2012-11-17 Age : 67 Location : East Anglia Regiment Action Man Battalion
ak615 Action Pilot
| Subject: Re: Outboard engine Mon Nov 26, 2012 1:07 pm | |
| Kids don`t try that at home | |
TALLY HO Armoured Car Commander
Posts : 719 Join date : 2012-11-16 Age : 57 Location : north wales
| Subject: Re: Outboard engine Fri May 24, 2013 9:25 pm | |
| I have one of those motors but the swing clip is missing !!!would the same work with the jungle explorer motor | |
ak615 Action Pilot
| Subject: Re: Outboard engine Sat May 25, 2013 8:01 am | |
| Yes it will, If you don't mind waiting a little while. I can get you another clip. _________________ There is pleasure in recognising old things from a new viewpoint. Richard Feynman | |
| Subject: Re: Outboard engine Sat May 25, 2013 9:50 am | |
| - ak615 wrote:
- Yes it will, If you don't mind waiting a little while. I can get you another clip.
Cheers that's great mate .... Let me know what u want for it ? | |
Danthecoat Crash Crew
Posts : 828 Join date : 2012-11-07 Age : 52 Location : ESSEX
| Subject: Re: Outboard engine Sat May 25, 2013 12:55 pm | |
| Subject: Re: Outboard engine Wed May 29, 2013 6:28 pm | |
| i found the clip for the outboard motor , but the base has snapped off , will have to try a bodge just to get it one , just for decrotive purposes | |
ak615 Action Pilot
| Subject: Re: Outboard engine Wed May 29, 2013 6:41 pm | |
| I`ll look for my spare at the weekend TH _________________ There is pleasure in recognising old things from a new viewpoint. Richard Feynman | |
| Subject: Re: Outboard engine | |
| Outboard engine | |
