 Repair Muscle Body Blue Pant Head
pachwerk
pachwerk
Repair Muscle Body Blue Pant Head Empty
PostSubject: Repair Muscle Body Blue Pant Head   Repair Muscle Body Blue Pant Head Icon_minitimeTue Sep 30, 2014 4:58 am
With age Muscle Body VAMs can loose there heads as the plastic connector rubs and eventually fails.
Repair Muscle Body Blue Pant Head Tutori10
Silicone sealer was used to repair(glue) this head.  Not really a way you should treat a patient.
(1) Start by removing any type of glue that may remain on the neck post.
Repair Muscle Body Blue Pant Head Tutori11
(2) Cut away any of the broken neck connector (the whitish thing) and remove all the residual debris.
Repair Muscle Body Blue Pant Head Tutori12
(3) Next gather a zip tie.  You want one that is roughly the strength of the original connector.  If you get one too sturdy the head will be stiff and very limited in movement.  If you use one that is too meek it will not last as long and the head may be floppy.
Repair Muscle Body Blue Pant Head Tutori13
(4) Bend the end of the zip tie as pictured.
Repair Muscle Body Blue Pant Head Tutori14
(5) Next we must remove the neck post that is hiding in the head cavity.  There is a slot near the top of the head where can grab with expanded needle pliers.
Repair Muscle Body Blue Pant Head Tutori15
If it doesn't budge try a cork screw or crochet needle.
Repair Muscle Body Blue Pant Head Tutori16
(6)Once the neck post pops out of the head we need to thread the prepared zip lock through the neck post slot.Repair Muscle Body Blue Pant Head Tutori17
(7) Next thread the end of the zip lock you bent earlier and poke it in to one side of the flesh colored retaining pin.Repair Muscle Body Blue Pant Head Tutori18
(8)Use your needle pliers or a paper clip to get a hold of the end of the zip tie as it loops under the retaining pin and pull towards you.Repair Muscle Body Blue Pant Head Tutori19
(9) Thread the end of the zip tie trough the neck post slot.
Repair Muscle Body Blue Pant Head Tutori20
Pull to tighten, don't over tighten or the head won't move much.
Repair Muscle Body Blue Pant Head Tutori21
(10) Cut the leftover zip tie end. Repair Muscle Body Blue Pant Head Tutori22
Push the head back onto the neck post firmly.
Repair Muscle Body Blue Pant Head Tutori23
There you have it.  Repair Muscle Body Blue Pant Head Tutori24
I tried this method after repairing another figure with the black stretchy cord.  I had more difficulty trying to get the cord looped inside the body cavity.  Give this a try.
PostSubject: Re: Repair Muscle Body Blue Pant Head   Repair Muscle Body Blue Pant Head Icon_minitimeTue Sep 30, 2014 8:54 am
very clever! great tip mate cheers
PostSubject: Re: Repair Muscle Body Blue Pant Head   Repair Muscle Body Blue Pant Head Icon_minitimeTue Sep 30, 2014 12:11 pm
pachwerk great how to . re the the black cord head if you put a loop of thread inside the body 1st it makes getting the cord out a lot easier try that next time
PostSubject: Re: Repair Muscle Body Blue Pant Head   Repair Muscle Body Blue Pant Head Icon_minitimeTue Sep 30, 2014 12:29 pm
Great upload for repairing the EEs head, to put him back in action
» Needs some help - full body restring for AT Muscle body
» MAM Head Repair
» YM33 Anime Head Sculpt, TBLeague S22A body
» Wanting to tranceplant a No-Face head onto a black gloved Mam body and I'm wondering if someone can help me.
» BP EE body leg fix
ActionManMobileOperations (AMMO) :: Help and Advice :: Repair, Hints & Tips & Useful Links-
