 Re-attach EE heads----no cone-------washer solution
brownboots
brownboots
Re-attach EE heads----no cone-------washer solution Empty
PostSubject: Re-attach EE heads----no cone-------washer solution   Re-attach EE heads----no cone-------washer solution Icon_minitimeTue Oct 11, 2016 1:20 pm
This is a solution I devised after loosing so many bids on Cones!!
Standard rubber Tap Washers.....
Make a loop of Shock Cord and tie through the washer, leave a little bit of give so the head can move.
Re-attach EE heads----no cone-------washer solution EEconector1
To make it easier soften the head slightly with a hair dryer or steam over a kettle, push the head
onto the washer, it should click when in place....and viola!...you'll have the best head replacement ever!
The Rubber in the washer should give the head more grip too so you can achieve better posing!
Re-attach EE heads----no cone-------washer solution EEconector2
These are standard washers you should be able to get them anywhere, even local Shops should
have them as standard!
Re-attach EE heads----no cone-------washer solution Washerpacket
There are other applications for this fix too.....
BBI G3 body.
Re-attach EE heads----no cone-------washer solution Headfix_02
Re-attach EE heads----no cone-------washer solution Atomicfix
Modern Joe Body.
Re-attach EE heads----no cone-------washer solution Joeconversion01_zpse48b7888
Re-attach EE heads----no cone-------washer solution Joeconversion_zps88b8ed2f
Have fun!!
PostSubject: Re: Re-attach EE heads----no cone-------washer solution   Re-attach EE heads----no cone-------washer solution Icon_minitimeTue Oct 11, 2016 5:18 pm
Great tip! No excuses for loose heads!
Re-attach EE heads----no cone-------washer solution 71ddd946-00ff-4072-b6b8-dbc7c968f945_zps49748100
PostSubject: Re: Re-attach EE heads----no cone-------washer solution   Re-attach EE heads----no cone-------washer solution Icon_minitimeTue Oct 11, 2016 8:09 pm
Superb tips Paul, excellent information great upload as always Very Happy Very Happy
PostSubject: Re: Re-attach EE heads----no cone-------washer solution   Re-attach EE heads----no cone-------washer solution Icon_minitimeTue Oct 11, 2016 10:30 pm
Excellent work!!!
Thanks for the tips, Double B!
PostSubject: Re: Re-attach EE heads----no cone-------washer solution   Re-attach EE heads----no cone-------washer solution Icon_minitimeThu Oct 13, 2016 7:33 am
Perfecto! Cool
Stonewall
Heavy Weapons
Stonewall
PostSubject: Re: Re-attach EE heads----no cone-------washer solution   Re-attach EE heads----no cone-------washer solution Icon_minitimeFri Oct 21, 2016 2:27 pm
Ordered washers to try this Very Happy Thanks:D
Re-attach EE heads----no cone-------washer solution Pbucket
» LT1 Aluminum heads
» Brettonian hooded heads
» Purposed Cone Rule
» Vortec Heads
» Is cone 6 hot enough?
ActionManMobileOperations (AMMO) :: Help and Advice :: Repair-
