| Help assembling a kitbash with a 40th AM (hands, boots) | |
+4Wolf_Soldier64 brownboots BAMComix Falcon 8 posters |
Falcon Painted Head (Hard Hands)
Posts : 126 Join date : 2014-09-25 Age : 47 Location : Brazil
| Subject: Help assembling a kitbash with a 40th AM (hands, boots) Tue Oct 21, 2014 4:39 pm | |
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) Tue Oct 21, 2014 7:47 pm | |
| It's very rewarding, that project you're after. You can find perfect gear in the 21st Century toys line, especially uniforms and weapons. And their helmets fit directly in the vintage head, which most modern AFs don't. I recommend you to use a Cotswold/GEARBOX body for this project: It's the very same vintage body design, but with bendable fingers hands, which will allow you to use the glorious modern gloves. The vintage heads fit perfectly in this body, no modification is needed. Sometimes (not always) you can put modern boots in vintage feet after submerging them for a few seconds in very hot water. You can trim a bit the figure's toes and toecaps, too. If you're after a certain vintageish look, then again the 21st boots are just perfect for that. Regarding weapons, mi advice is to stick to 21st stuff while possible |
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) Tue Oct 21, 2014 8:21 pm | |
| - koenig wrote:
- It's very rewarding, that project you're after. You can find perfect gear in the 21st Century toys line, especially uniforms and weapons. And their helmets fit directly in the vintage head, which most modern AFs don't.
Sometimes (not always) you can put modern boots in vintage feet after submerging them for a few seconds in very hot water. You can trim a bit the figure's toes and toecaps, too. If you're after a certain vintageish look, then again the 21st boots are just perfect for that. Regarding weapons, mi advice is to stick to 21st stuff while possible Thanks a lot, Koening, but as I said I alread have a set, this one: And the figure, this one: But I will take your advice regarding a cotswold body. I am only interested in keeping this 40th AM head, I like the quality and likeness of their job. According to you, cotswold's hands dont need any adjustment? Because its near impossible put gloves in this figure from modellersloft. I notices that on your own veteran you switched hands for one with bendable fingers? Do you think these hands I posted can be plugged into a modellersloft or cotswold body? As I said the boots are problem because 21st doesnt have any modern boots used by army/rangers. Their stuff is from the 90s early 2000s. | |
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) Tue Oct 21, 2014 8:23 pm | |
| Oh wait, you mean gearbox figure have bendable fingers? I dont know them! Only cotswold. | |
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) Tue Oct 21, 2014 8:27 pm | |
| - Falcon wrote:
- Oh wait, you mean gearbox figure have bendable fingers? I dont know them! Only cotswold.
Yep! My Veteran is a Gearbox body with vintage head. Gearbox is (was) a Cotswold division. Try your new boots with the hot water trick. Besides, I think that Gearbox bodies have smaller feet (being based in the Takara body) |
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) Tue Oct 21, 2014 9:47 pm | |
| I did a little research after that and I found them. I didnt knew these bodies, they are awesome. But what about the feet in your kitbash? Did you removed the feets? What boots are those? | |
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) Wed Oct 22, 2014 6:37 am | |
| Those boots are BBI ones, they went fine with the hot water trick on the Gearbox feet. Dragon boots usually are OK too. |
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) Wed Oct 22, 2014 12:42 pm | |
Posts : 14883 Join date : 2012-11-07 Age : 51 Location : Birmingham, England
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) Wed Oct 22, 2014 12:57 pm | |
| Brownboots would be the man to ask Falcon | |
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) Wed Oct 22, 2014 12:58 pm | |
| - Blondeactionman wrote:
- Brownboots would be the man to ask Falcon
He often posts here? | |
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) Wed Oct 22, 2014 1:58 pm | |
| I will drop him a mate with a link to this thread | |
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) Wed Oct 22, 2014 2:16 pm | |
brownboots Admin
Posts : 523 Join date : 2013-04-10
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) Wed Oct 22, 2014 4:47 pm | |
| Yes you can replace the Joe head for a 40th...see pic. Same standard washer screwed into the neck post. The figure on the right is one of mine with a Joe body and a 40th head. | |
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) Wed Oct 22, 2014 5:05 pm | |
brownboots Admin
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) Wed Oct 22, 2014 9:49 pm | |
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) Wed Oct 22, 2014 10:29 pm | |
| Yeah I am not a modder and your job looks awesome. What is this little piece you putted on his neck and where I can find it? A washer?
Do you have a pic of him without the scarf/shirt so I can see how the neck connected to the body?
And this body IS taller than vam's right?
Thanks A LOT!
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) Thu Oct 23, 2014 11:56 am | |
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) Thu Oct 23, 2014 10:55 pm | |
| Some friends showed me pics today and GI Joe/VAM has an issue with his head: it has part of his neck on it so in all bodies previously mentioned, either he becames short necked or with an strange long neck.
I need help finding a cool body where I can adapt this head without using epox, just minor connectors as Brown did.
I'd like to see the photo of that Joe on a BBI too, Brown. Please, please... I am rushing because a friend is going to visit USA and I'll ask him to bring some cloths for this bash. If it is impossible to make this swap, I will drop the whole idea. | |
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) Fri Feb 06, 2015 1:26 pm | |
| Top work!, he looks great! | |
Wolf_Soldier64 Moderator
Posts : 2476 Join date : 2012-11-12 Age : 59 Location : Reading, Berkshire
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) Fri Feb 06, 2015 1:37 pm | |
| Nice work, great photo good upload _________________ Its better to Burn out than fade away
Posts : 7865 Join date : 2012-11-27 Age : 63 Location : Pennsylvania USA
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) Fri Feb 06, 2015 1:48 pm | |
| Looking good! _________________ JIM...
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) Sun Feb 08, 2015 7:29 pm | |
| Thanks, guys! My original idea was use this figure to assemble a modern day green beret although now I am considering using a Masterpiece head if I find one for sale. Lets see. | |
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) Sun Feb 08, 2015 8:11 pm | |
| - Falcon wrote:
- Thanks, guys! My original idea was use this figure to assemble a modern day green beret although now I am considering using a Masterpiece head if I find one for sale. Lets see.
When you get things figured out please post more pics... _________________ JIM...
| Subject: Re: Help assembling a kitbash with a 40th AM (hands, boots) | |
