Subject: World Box AT017 Body. Need Advice, help. Fri Mar 26, 2021 11:35 pm
I've just received a World Box AT017 body from Urban Samurai. It's my first World Box body and I'm very impressed with the quality and the heft. Way better than the cheap bodies. The only thing is, I can't figure out how to put a head on it. it has no neck and the neck pin sticks very far out, meaning that the neck adapters that I have don't have a cavity deep enough to use with this body. Before I go out and try to buy adapters or necks that I don't know will fit, does anyone have any experience with this body and if so, can you share your insights?
RealSarahdactyl Action Sailor
Posts : 495 Join date : 2020-07-30
Subject: Re: World Box AT017 Body. Need Advice, help. Sat Mar 27, 2021 12:41 am
Hi Gary, Congratulations on your first World Box!
Did the figure not come with several neck pins? There should be two or three.
It looks like AT017 has a neck that fits over an internal ball on the torso, then another peg with a ball at either end fits into the neck. I THINK the Punisher I put together for my brother was on this body. I will try to dig it out later and check, as I am pretty sure he left it here with my stuff. If you have the different pins, just dip the neck in a cup of boiled water to soften, then pull out the pin to swap for different lengths.
Subject: Re: World Box AT017 Body. Need Advice, help. Sat Mar 27, 2021 12:45 am
Oh shit. I'm looking at the AT017.. did it come with a neck?
Kimono Troop Command French Resistance
Posts : 2122 Join date : 2020-07-25
Subject: Re: World Box AT017 Body. Need Advice, help. Sat Mar 27, 2021 1:03 am
It came without a neck. There is a long neck pin in the body and I see no way to get it out, and two shorter pins that I have no idea how to get into the body. I did however figure out a solution by pulling the ball joint adapter out of a neck I was using on another unfinished figure, drilling it out a bit with a large drill bit and then making an adapter by carving one out of a Mars art eraser, as I have for a couple of the smaller Phicen figs. Still though, there must be something I don't quite understand or which must be available someplace.
Subject: Re: World Box AT017 Body. Need Advice, help. Sat Mar 27, 2021 1:10 am
Ahh, I think then, this body must be designed for sculpts that fit on these style necks and adapters.
I can dig around and see what components I have from other bodies that might work. I must have a neck or semi-sphere type thing somewhere. Just have to find it.
Subject: Re: World Box AT017 Body. Need Advice, help. Sat Mar 27, 2021 1:13 am
thanks much!
Chip Deep Sea Diver
Posts : 1639 Join date : 2014-02-26
Subject: Re: World Box AT017 Body. Need Advice, help. Sat Mar 27, 2021 12:29 pm
Hi Gary . I have a couple of those bodies , it`s annoying Worldbox supplied this figure with no neck . As all their others seem to have one . It`s a good solid body though . The neck pin does come out . Heat up the neck part first with hot water as suggested , or my preferred method of a hair dryer . Get it hot , then use a pair of thin nosed pliers to pull it out , place the pliers under the ball part if you can , and use considerable force to pull it out as straight as you can . It does take some pulling , be brave . Quickly put the shortest pin in using the pliers, you need to use some force here too , I found the shortest pin works best , and avoids the Giraffe neck appearance . You will need a neck adaptor set like in the link below . There are a few types available on eBay . The beauty is you can use either neck sculpts or no neck sculpts .
I used this body on My Animal figure , and am pleased with it .
_________________ " There will be no Mercy ." Chip Hazard .
Subject: Re: World Box AT017 Body. Need Advice, help. Sat Mar 27, 2021 12:37 pm
Thanks. I may give that a try. In the meantime, I found a solution that seems to work; I took a neck I was using on a cheap figure, pulled out the neck adapter, drilled a bit deeper with larger drill bit, and then put in one of my improvised neck adapters carved out of a soft rubber art eraser. It works pretty well, but the neck and the body are not a good colour match for one another.
Chip Deep Sea Diver
Subject: Re: World Box AT017 Body. Need Advice, help. Sat Mar 27, 2021 12:43 pm
Matching head and body parts colour wise is a real gripe for me . It`s trial and error for us all I feel .
Subject: Re: World Box AT017 Body. Need Advice, help. Sat Mar 27, 2021 9:12 pm
Hey Chip,
Did as you instructed. It worked. Thanks for the help. Thanks also to Sarah for your help. i knew I could count on members here to help me out with this.
Gary
Chip Deep Sea Diver
Subject: Re: World Box AT017 Body. Need Advice, help. Sat Mar 27, 2021 9:30 pm
Glad you got it sorted , hope we get to see who he ends up as .
Subject: Re: World Box AT017 Body. Need Advice, help. Sat Mar 27, 2021 9:35 pm
It's just our old friend Feldewebel Heinze Pfeffer, (sgt Pepper) given a new, better quality body to replace the cheap one I was using before.
Posts : 14894 Join date : 2012-11-07 Age : 51 Location : Birmingham, England
Subject: Re: World Box AT017 Body. Need Advice, help. Sun Mar 28, 2021 8:04 am
Looking forward to the pics Gary
Subject: Re: World Box AT017 Body. Need Advice, help. Mon Mar 29, 2021 5:57 am
Hey Chip,
Did as you instructed. It worked. Thanks for the help. Thanks also to Sarah for your help. i knew I could count on members here to help me out with this. Gary
Hey Gary, I have found bits. Between two nudes I'm not really using I have a neck and semi circle style adapter if you need.
Subject: Re: World Box AT017 Body. Need Advice, help. Mon Mar 29, 2021 9:38 am
Thanks Sarah. I don't. I had those parts too, but couldn't figure out how to use them with this figure because the neck pin was so damned long. It did not think it was possible to take it out, but Chip explained to me how to do it and replace it with the shorter neck pin. I did as he instructed...heating with the hair dryer and pulling it out with a pair of pliers, and voila! it worked. I had not known this was possible and was afraid of breaking the pin.
I thanked both you can Chip for your advice and assistance in an earlier post. I was hoping you would read it before going to any trouble but I guess you didn't see it, so I'll take the opportunity to thank you now.
Also, I was on the BigBadToy store site earlier today and saw some items that made me think of you and your dios, so let me give you a link to them. As your characters and dioramas seem much more grounded in reality than mine, I thought some of these items would fit in well with your 1/6th scale world. Alas, most of them are pre-rder but a a few are in stock now.
Posts : 3947 Join date : 2018-03-22 Location : South Central Utah, USA
Subject: Re: World Box AT017 Body. Need Advice, help. Mon Mar 29, 2021 3:48 pm
Well... seeing all those links answers a question I have had for a while. I've seen some impressive dioramas of shops and garages since I joined these action figure forums in the past couple of years, and I've wondered how some of the builders create such scenes. Now I know. The trick apparently goes something like: "Wot's this? An extra ten grand in me pocket? Cor, I reckon I'll build me a miniature diorama!"
I like those overalls, but at seventy bucks, I'll be sticking with old GI Joe jumpsuits. That's more than I paid for the overalls for my 1/3 scale Smart Dolls.
A toolbox or two would be nice to have, and it's not too hideously expensive. I'm hoping they are still in stock when my eBay funds credit to my bank account later this week. (The new eBay payment system is really annoying, but that's a subject for another topic.)
_________________ ... DAVE
Subject: Re: World Box AT017 Body. Need Advice, help. Mon Mar 29, 2021 4:17 pm
Damn, those are some nice accessories! I just paid up for my Dam Toys Leon, so I have to taper spending for a bit. Thanks for the links Gary
Subject: Re: World Box AT017 Body. Need Advice, help. Mon Mar 29, 2021 4:19 pm
I like the overalls too because they look a lot like the ones worn by the automotive club in Girls und Panzer, which I apparently cannot stop watching...over and over again.
The thing is of course, you also get boots, a belt and a cap for your $70.00, though I still find that very expensive.
Subject: Re: World Box AT017 Body. Need Advice, help. Mon Mar 29, 2021 4:49 pm
No problem, Sarah. With the exception of the overalls, which have been around for a while, all the other stuff is new and when I saw the dumpster and phone booth, I immediately thought of your street dios, and as for the tools and tanks, I thought of Mini-Sarah.
Gary
Subject: Re: World Box AT017 Body. Need Advice, help. Mon Mar 29, 2021 5:10 pm
As far as expenses go....Geez! I don't even want to think about how much money I'm spending on this hobby. It's terrifying. I just bought a roll of blue seamless paper to simulate a sky for Dinosaur Valley (or any outdoor scene) and had it delivered to my office, where it was waiting for me as I got in this morning. Fortunately, I can use it for other photo projects, if I need to. (actually, I'm not likely to...unless I use if for a blue chromakey backdrop for sci-fi stuff or something.....
FIELD STATION 42 Admin
Subject: Re: World Box AT017 Body. Need Advice, help. Mon Mar 29, 2021 11:23 pm
Considering what 1/6 scale action figure shoes cost on eBay, yes, having the boots and belt included makes it a little bit less unreasonable. Or so I began to convince myself, until I realized I could go to Walmart (or Canadian Tire for you, maybe) and buy an inexpensive set of coveralls and cheap boots for myself for less than $70.
That said, you had to note how closely those coveralls resemble the Girls und Panzer look, didn't you?
Do you have a preferred DVD or Blu-Ray collection of Girls und Panzer? Or do you watch a streaming version?
I wish I could stop buying random stuff so I could save up enough for a 1/6 tank.
As far as expenses go....Geez! I don't even want to think about how much money I'm spending on this hobby. It's terrifying. I just bought a roll of blue seamless paper to ... or something.....
I know, right? It's that "or something" that makes almost any cool little thing seem, well, cool enough to need! Or to justify. Like, say... the decorative map paper I purchased "under the influence" of someone on this forum. Or the... pretty much any of a hundred examples. I need to start using some of this stuff rather than buying it for projects I'm intending to do.
Anyway, it sounds like you've pretty much sorted out your body issues. Well, your action figure neck peg issues, I should say. I have a head I need to find a body for, myself. I'll go take care of that right after I finish posting this, rather than putting it off as usual.
Subject: Re: World Box AT017 Body. Need Advice, help. Mon Mar 29, 2021 11:53 pm
We have both Walmart and Canadian Tire here. You can buy coveralls at both, but not nearly so cool looking as the turmeric coloured ones that look like they came straight out of the automotive club on Girls und Panzer. I have a DVD. I keep saying I'm gonna get myself a Blu-ray player so that I can by Der Film, and The Final Chapter, and all the OVA's but I keep spending the damned money on.....guess what?
But as to Girls und Panzer...cute girls having tank battles! What could be more fun. I would have enjoyed high school a lot more if we had had a Sensha-Do program in my High School, which believe it or not, was named "Riverdale."
I need to save to buy a tank also. I'm really hoping that Dragon will eventually release a Stug III or a late model Panzer III or Panzer IV. If they released an M4A3E8 Sherman, (Easy Eight) with the 76mm gun I'd be all over it.
The Stug would be an instant seller, I think and just like the real ones, they could keep the costs down because it wouldn't have a turret.
Subject: Re: World Box AT017 Body. Need Advice, help. Tue Mar 30, 2021 12:31 am
Since you attended Riverdale High, the obvious question would be... nah, never mind, you've probably heard that ten-thousand times too many!
I need to upgrade my Girls und Panzer discs. Most are from back when eBay was the only source and quality was inconsistent and it was hard to tell the real thing from crummy bootlegs. I see there are legit Blu-ray releases of everything now. So what else can I sell on eBay...?
I'm supposed to be finding a body to go with a head, right? Okay, I'm on it... right now!
Subject: Re: World Box AT017 Body. Need Advice, help. Tue Mar 30, 2021 2:50 am
If the Riverdale question you were going to ask was "Who would I want to date: Betty or Veronica; my answer would be that while they are both very cute, if I could date any cartoon character I would want to, it would be one or more of the girls in Girls und Panzer, especially Maho, (Miho's older sister) Hana Isuzu, or Momo Kawashima, who despite her cold, hard exterior, has a really sentimental side she doesn't want others to know about.
And now that I've totally ruined your evening with by making you wonder which Girls und Panzer cartoon character you might like to date if you were Japanese anime character, I'll try to get back to shooting a few test shots with my new backdrop.
Subject: Re: World Box AT017 Body. Need Advice, help. Tue Mar 30, 2021 4:57 am
And now that I've totally ruined your evening with....
Pretty much, yeah, but... much more pleasant to contemplate than current world events.
